WTB: CF-18/19 Vehicle Mount G&J or Panasonic is fine!
Re: WTB: CF-18/19 Vehicle Mount G&J or Panasonic is fine!
#11 Post by Rob »
I think the bottom one will work! :)
Is there any way you can test it with a CF-19? In particular, I need the Audio out (for my speakers), the DC power port (obviously) and the USB's to work. Also, I have the OEM GPS in my CF-19, so it has the little bump out on the rear right side of the computer. I want to make sure it'll fit in there with that GPS :)
Do you have the key to this animal? I would be SURE that it can lock as without a lock, someone will just steal my baby.
orphanlr
#12 Post by orphanlr »
OK..........
1. Yes I can test it with a cf-19
2. I will try speakers with audio out
3. not sure I have the corrrect lind power supply in the box but can try it with a AC plugged into the mount...
4. I'll check the USBs
5. There looks to have plenty of room for your gps
6. Yup, their is a key as seen in the first set of pics.
I'll be back........................
orphanlr
#13 Post by orphanlr »
Rob,
I put my cf-19 in it and fits fine, used an ac adapter to the mount and the laptop charging light came on, plugged speakers into the base and sound played, put a usb in each of the two slots and they worked.
orphanlr
#14 Post by orphanlr »
Also, their are some of the Gambler Johnson ones you wanted now listed on ebay.........................
#15 Post by Rob »
orphanlr wrote:Also, their are some of the Gambler Johnson ones you wanted now listed on ebay.........................
$500??? NO THANKS!
#16 Post by Rob »
orphanlr wrote:Rob,
This is great!
I'll take it! How much do I owe you?
orphanlr
#17 Post by orphanlr »
Email or PM me an address for shipping, you cover shipping and whatever you think is fair, you wont hurt my feelings. :)
#18 Post by Rob »
I just bought this:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0798398138
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0798398845
Sorry Sam! This is more of what I was looking for! It's like an angel above made these listings for me... I needed a mounting and docking for my boat and one for my truck and this guy just happened to have BOTH! What are the odds!?
orphanlr
#19 Post by orphanlr »
No worries, glad it worked out
#20 Post by ADOR »
orphanlr wrote:No worries, glad it worked out
If he is happy let me know what you would like for the other one or both of them.
Thanks.
