CHINA PORT COVERS + OTHER PARTS
Gear6
Re: CHINA PORT COVERS + OTHER PARTS
#11 Post by Gear6 »
Blair, have you read my PM on NBR ?
I want to buy the 3 oem covers (dc, usb, serial) from you, and maybe the big metal door on the back.
C1mk1&2, CF19mk4, CF30mk1&mk3
#12 Post by toughasnails »
Damn...yes I did but forgot to PM you. Sending one now.
Gear6
#13 Post by Gear6 »
Hi Blair,
I'm waiting for an answer to my PM from last week.
#14 Post by toughasnails »
I just sent you a PM. :)
logo oem.JPG (78.14 KiB) Viewed 15575 times
CF-30 logo aftermarket.JPG (71.82 KiB) Viewed 15575 times
Gear6
#15 Post by Gear6 »
Hi Blair,
I received the 3 OEM covers from you. Man, what a difference :D perfect fit and function.
The rubber on the inside and the ridges make a very good seal, and it keeps the covers closed. Not to mention the screw holes are the correct size, and the thin plastic area that bends over the bottom edge is wide enough for it to sustain many open/close cycles.
Thanks :D
#16 Post by toughasnails »
That's great , glad you got them. Now you see what I mean...big difference in the OEM ones. :D
