It is currently Mon Feb 18, 2019 7:00 pm
 Post subject: CF 28 model number
PostPosted: Wed Jul 15, 2009 8:23 pm
I cant seem to locate my model number in the download page at panasonic can anybody help CF28 PTJAZDM is not found and every driver I download is not supported because this machine does not appear from the list
 Post subject: Re: CF 28 model number
PostPosted: Wed Jul 15, 2009 9:00 pm
Here is the first driver that you need after a fresh xp instalation
The chipset driver
http://www.panasonic.ca/PDP/Drivers/d-2001-645_inf.exe
Download and see if it works
Alex
PostPosted: Thu Jul 16, 2009 8:56 am
Yes sir it worked. Can you direct me to where you located that driver. My model number does not appear from the drop list on panasonic driver page
PostPosted: Thu Jul 16, 2009 8:59 am
One other thing to note the only listing in the drop down box is CF28S(mk3) obviously not my machine so what can I do
PostPosted: Fri Jul 17, 2009 5:13 am
Here is the link
http://www.panasonic.ca/english/custome ... equery.asp
check the o/s box for xp
model number is cf28
then search
Look for drivers that are for cf-28P models ,It's is a mk2 model
They are mostly in the middle
Alex
