It is currently Fri Sep 21, 2018 11:49 pm
PostPosted: Sat Aug 13, 2011 4:49 pm
Well I am trying to restore my CF-18 MK1 and I keep getting Error #49 write fault I figured maybe the disk 1 was bad but burned another one and still get the error at 17% and also tried another external cd-rom . Anyone got any idea's what to try next.
Cel Google Pixel XL
PostPosted: Sat Aug 13, 2011 10:30 pm
I had a similar problem with a CF-18. I wiggled the USB connector on the external CD at the CF-18 end a few times and it seemed to go away. Maybe my CF-18 USB connector was loose or tarnished and not making a good connection.
PostPosted: Sat Aug 13, 2011 11:27 pm
Well so far I have tried 5 harddrives, 2 different cd enclosures, 4 cd drives and I just finished burning a new set of restore disks AND I even tried to use a XP Pro OEM disk and I get to 19 minutes remaining in setup and it just stays there " installing start menue"...think thats what it says :confused: :help:
Cel Google Pixel XL
PostPosted: Mon Aug 15, 2011 10:14 am
I was just gonna say: Scratched disc?? Nope! :sucks:
http://www.toughwiki.com
http://www.robsnetworks.com
http://www.giganethosting.com
PostPosted: Mon Aug 15, 2011 1:43 pm
Wish that's all it was but running memory test now and seeing a lot of red....not good
It was the cheap external cd-rom that was causing the problem . I bought a Panasonic CF-VDRRT3U and installed the restore disk in not time at all.
http://www.ebay.com/sch/i.html?_trksid=p3984.m570.l1313.TR0.TRC0&_nkw=CF-VDRRT3U&_sacat=0&_from=R40
Cel Google Pixel XL
Users browsing this forum: Bing [Bot] and 1 guest
