It is currently Sun May 31, 2020 5:02 pm
PostPosted: Mon Dec 13, 2010 9:33 am
I have an annoying problem. :doh:
When i connect the ac adapter, the laptop boots to windows.
I cant find anything in bios or in power management to prevent this
Any ideas how to disable this function ?
CF-18KEH01VE
PostPosted: Mon Dec 13, 2010 10:43 am
LMAO... I have the problem where if I UNPLUG my CF-30 from the power OR unplug a USB mouse it powers up from standby... :wtf:
~ISDN intertube lines are the best - It still does NOTHING~
http://www.toughwiki.com
PostPosted: Mon Dec 13, 2010 11:38 am
Mine powers up from nothing or from standby the moment i connect the ac power
no mater if the battery is full or empty.
It looks like the auto power up on a desktop (bios function) but i cant find it nor in bios or in Windows :damnit:
PostPosted: Mon Dec 13, 2010 1:42 pm
Can you please expain more detail. From my understanding is that it power up even if the unit is off at the time you plug the ac on the wall?
PostPosted: Mon Dec 13, 2010 2:19 pm
That is correct (he also do it if he is on standby)
Normally i plug the 18 to ac coming home from work, now i have to open hem and shut down after connecting to external power (then he stay down).
PostPosted: Mon Dec 13, 2010 4:17 pm
Quote:
http://www.nirmaltv.com/2010/03/17/how-to-disable-the-automatic-restart-on-system-failure-in-windows-7/
Here's another one.
Quote:
Click “Start”, on “Computer” click right mouse button and select “Properties”, click “Device Manager”, select “IEEE 1394 Bus Host Controllers” group, only contains one device called “VIA 1394 OHCI Compilant Host COntroller” on that click right mouse button and select “Properties”, select “Power Management” tab, and finally check the “Allow the computer to tur off this device to save power” box!
That’s all folks. After that the computer power down normally every time.
And the third one was related to a print spooler error. I like the second one and if Rob would send me a CF-30 to test I could figure it out. :rolleyes:
FWIW for sure.
PostPosted: Tue Dec 14, 2010 12:20 am
Gork,
I don't think it is windows related, he boots from off when i plug to the adapter.
I think he is moddet for use in a car dock so that he powers up with the ignition of the car
PostPosted: Tue Dec 14, 2010 1:11 am
Post your bios info
The first thing I thought of when I read your post is that would be handy for trunk mounting
Panasonic had some different bios versions for docking use
PostPosted: Tue Dec 14, 2010 1:48 pm
Hi Tomcat,
Bios version is V4.00L13
Embedded controller V4.10L43
Users browsing this forum: Majestic-12 [Bot] and 1 guest
