It is currently Sun May 31, 2020 5:48 pm
PostPosted: Tue Jan 19, 2010 10:01 am
Okay, I have a CF-18 (1.2Ghz) with the digitizer screen, I am using XP Pro with SP3. I have a Wacom MP-200 pen. The digitizer is enabled in the BIOS. What do I need to do to get it to work?
PostPosted: Tue Jan 19, 2010 12:13 pm
You need to load the digitizer driver
Here is a link to the driver to make your digitizer work
http://www.wacom.com/U/drivers/IBMPC/co ... 508-2a.exe
Alex
PostPosted: Tue Jan 19, 2010 5:30 pm
Thanks much Alex! That did the trick...Boy, it sure does work a lot different from a standard touch. Still trying to get used to the "hover mode". :confused:
