It is currently Tue May 26, 2020 4:39 am
 Post subject: Windows 7 on CF18
PostPosted: Fri Dec 25, 2009 5:26 pm
ANybody running windows 7 on their 18 yet. If so I need a fix if possible. 7 makes my tablet run alot smoother. Programs open faster and boot up speeds up too. My only problem is that my hotkey driver is incompatible and of course I cant use them and adjust my screen brightness at all
 Post subject: Re: Windows 7 on CF18
PostPosted: Fri Jan 15, 2010 10:08 pm
I have a CF-18NJ Toughbook. I recently upgraded to Windows 7. Everything works much better and faster than XP. My big problem is that I do not have any sound. I believe I have a Realtec AC 97 Audio Sound card. I have installed all versions of the driver with no luck. I would appreciate any help with this problem. My second problem is that I do not have any use of my touch screen like I did with XP. Any suggestions are greatly appreciated on how I can get sound and the touch screen to work. Thanks!!
PostPosted: Sat Jan 16, 2010 12:50 am
Have you tried the CF-19 Vista Drivers?
PostPosted: Sat Jan 16, 2010 11:17 am
CF-19??? or did you mean CF-18 Vista drivers Azrial???
http://www.toughwiki.com
PostPosted: Sat Jan 16, 2010 4:38 pm
No, he meant 19. Alot of 18 users are finding luck using the 19 vista for some reason. Perhaps they are the same, or just more compatible. Not sure, but it was mentioned.
~Paul ;)
Philippians 4:6-7"
Panasonic CF-29 Toughbook - 1.6Ghz - 100 GB 7200 RPM HD - 1.5GB of RAM - GPS - Internal WiFi - Sierra Wireless EVDO - 13" Touchscreen - DVD/CDRW Drive - Media battery - BT enabled with BT PCMIA mouse - backlit keyboard - :D
Anyone for a game? Look for Doobi!! :p
http://www.letsplaychess.com
PostPosted: Sun Jan 17, 2010 10:47 am
I put Win7 RC1 on my 18mk2.
As Doobi mentioned, I used mostly CF-19 Vista drivers.
However, I was never able to get the front panel hotkeys working, so I wen't back to XP
nine
nine
Toughbooks, I have a few :)
PostPosted: Sun Jan 17, 2010 3:07 pm
I tried sound drivers from cf-18 vista upgrade and cf-19 vista upgrade. Still cannot get my sound. I am happy to say that everything else works including my hotkeys and touchscreen. I guess I have to do without sound for a while until I can figure this out.
