Model Number ?????????
- twillingham
This just arrived CF-18 with Red Cover which I have not seen an 18 with a red colored back. Anyway, I cant find the darn model number. Not on the bottom, the configurator doesnt yield me anything and Its not in the bios. System information viewer, nothing Is there another way to tell what the model number is
Re: Model Number ?????????
Never seen it missing in the bios
Does it list the bios revision number in the bios, and the s/n
If so post what you find
Alex
Alex
- twillingham
I havent seen it before either. BIOS V1.00L12
Emb Controller V1.00L22
Its a mk-1 900mhz model
Where did you buy it, and idea of its history
Alex
Alex
- twillingham
it is the damnest thing. I downloaded a MK1 driver from the global site and it says does not support. I bought it from a guy over in Hawaii.
I wonder if this thing is stolen maybe???
Just install wirar
Winrar will unpack the files
Then put them in C/utilitys , and either run the exe file for each or in device manager direct to the correct file in c/utilitys
Alex
Alex
- twillingham
Just because I cant find a model number and the MK1 which I know it is doesn't match the drivers. Besides This guy didnt seem like the type. I live in Atlanta ga and I sent him money and he was honest enough to send the PC to me He could have just as easily kept the money.
What does it have for options
Other than our normal usa canada models ,there is some strange configurations out there
It might have been purchased and modified for some use by military,
Can you take a pick
I have never seen a red base before lol
Alex
Can you take a pick
Alex
- twillingham
I will take a pic It doesnt have a red base The base and edges are black. The lid's back is red. It is some crazy configuaration on this puppy
