Bluetooth Not Ready
- twillingham
Bluetooth Not Ready
has anybody had problems trying to work with a bluetooth mouse. When I start bluetooth manager it says bluetooth not ready. Does anybody know what is causing this
Re: Bluetooth Not Ready
Is this the first time you have used a bluetooth device
Is bluetooth enabled in the bios
Is there an icon on the taskbar that lets you add a device
Alex
Alex
- twillingham
Yes this is the first time I did remember windows updating the driver I have an icon in the system tray and a lightning bolt for bluetooth switch indicator on I will check the bios and let you know
