It is currently Sun May 31, 2020 6:03 pm
PostPosted: Tue Sep 09, 2014 5:46 pm
According to this page a CF-18 MK5 takes PC3200 DDR2 memory.
http://www.panasonic.com/business/tough ... aqs-18.asp
I ordered that from Newegg but got PC4200 DDR2 memory instead. Did they make a mistake or is that a valid substitution?
PostPosted: Tue Sep 09, 2014 5:59 pm
Well most memory sites say it should
Dell 1710
Cel Google Pixel XL
PostPosted: Tue Sep 09, 2014 6:43 pm
Does it fit in the slot?
Does it boot?
It should work fine....
PostPosted: Wed Sep 10, 2014 1:18 pm
If it doesn't fit then use a hammer.... That'll help you make it fit! :D
http://www.toughwiki.com
PostPosted: Thu Sep 11, 2014 9:42 am
Felt a little nervous about the hammer, so I used a rubber mallet instead. :violent:
Memtest checked out perfect, and now the machine has some nice elbow room.
