It is currently Sun May 31, 2020 4:48 pm
PostPosted: Mon Sep 09, 2013 6:11 pm
Hey guys
It looks like I may be on the way to a Tough book addiction and as fellow TB junkies
I was hoping you could point me in the right direction. I acquired my second Tough book a few
Days ago, a truly pristine CF 18 Mk5 (cf-18 NHHZXBM) with only 300 hours, GPS and touch
Screen, 1024 mb mem with Linux loaded. The touch screen and GPS did not work with the Linux but
Everything else SEEMED to work ok, so when I got it home I restored Windows with the factory restore
Disks and installed all updates including SP3 from MS.
Well after many hours this is where I am at 1: it seems a little slow but I guess that is to be expected.
2: the touch screen does not work, it sometimes reacts to being touched and using the touch screen
Test it did move the red + around but that’s it. I did apply the two reg patches for the touch screen
And GPS. 3: the touch pad works but is VERY sensitive, often making false clicks.
A word of warning, I know enough about computers to be dangerous BUT I an
A total Tough book NUBEE and any help would greatly appreciate.
TNX Jim
PostPosted: Mon Sep 09, 2013 7:09 pm
Hi Jim!
The touchscreen sounds like it is failing, a common problem I'm sorry to say. Later models CF-18 and CF-29, and early CF-19 have touchscreens that often fail. You can replace it with aftermarket or maybe see if member Sadlmkr (Jeff) can repair it.
The GPS should be putting out NMEA text at 4800 baud on COM3. Try downloading a GPS utility like WinFast Navigator and see if it is putting out data. That GPS may take several minutes under an open sky to get a good fix.
Recently I worked on a late mode CF-18 that is running slow. I wonder if one of the recent MS updates causes issues with CF-18's? I've done it before months ago without any issues, but possibly a recent update is not compatible? Just a hunch ...
PostPosted: Mon Sep 09, 2013 8:05 pm
Springfield wrote:
Hi Jim!
You know I was afraid you were going to say that the screen may be failing and that is a bummer but something I can live without, otherwise it seems
it seems to work great. The GPS works fine, I use it with MS Streets and trips. Do you have any idea why the touch pad is so sensitive the false clicks are a pain?
One final question: What do I tell wife when she asks why I need so many computers?????
PostPosted: Mon Sep 09, 2013 8:21 pm
If you figure this one out, please share with the rest of us. We just live in the dog house perpetually.
(Yes, pun intentional :P )
