It is currently Thu Jun 21, 2018 2:15 pm
PostPosted: Fri Jun 21, 2013 10:04 am
Hello all
Jim here, a certified Tuff Book
NuBee with a dumb question.
I have a CF18-MK5 that works great and to try to speed things up a bit
I have purchased a Transcend TS64GPSD330 64 GB
pata SDD . Now for the dumb question
The SDD has three options 1: Master, 2: Slave 3: Cable
being new to SDD's most HDD I have installed have a setting
for master,slave, cable and SINGLE. anyone know for sure what the setting for
SINGLE on the Transcend TS64GPSD330-64GB
BTW this forum rocks, Thanks Jim
PostPosted: Fri Jun 21, 2013 10:36 am
Don't know for sure about the Transcend, but 'Master' would be the setting I would use.
CF-52GUN
PostPosted: Fri Jun 21, 2013 6:30 pm
I've put Transcend in CF-18 and CF-29 with good results. If you're using Win XP, be sure to load CCleaner and go to the lowest tab Tools then check Erase Unused Space (or similar) ;-). Its like TRIM for Win7 and keep the SSD running fast.
PostPosted: Sat Jun 22, 2013 3:19 am
Thanks for the tip, good info....
How did you set the option plug ie master, slave. or cable on the SDD
Thanks Jim
PostPosted: Sat Jun 22, 2013 6:35 am
I don't recall adjusting any jumper out of the box, maybe I didn't notice that. But I'm pretty sure Panasonic laptops need both HD and CD to be set to Master.
PostPosted: Sat Jun 22, 2013 7:39 am
Sounds good to me, unless I hear different I'll give that a shot
Tnx Jim
PostPosted: Tue Dec 30, 2014 5:04 pm
I have a 32Gb Transcend ssd and have always used it just as is and never changed the jumper settings from the factory.
CF-18 MkII
1280 Mb Ram
1.1 MGz Centrino
Factory BT and GPS
8602+S 600 Mw Wifi
32 Gb Transcend SSD
Rubber Back-lit Keyboard
Linux Mint 17.1 Mate Edition
