It is currently Sat Feb 16, 2019 10:29 pm
Post new topic  Reply to topic  [ 11 posts ]  Go to page 1 2 Next
 Post subject: Should I buy a CF-29L?
PostPosted: Sun Jun 05, 2016 2:03 pm
I saw a very cheap CF-29 on Ebay, but it's missing the charger, battery and caddy, should I go for it?
CF-29LAQGZBM is the serial btw.
PostPosted: Sun Jun 05, 2016 3:03 pm
I like MK4s. No TPM otherwise pretty much identical to MK5.
PostPosted: Sun Jun 05, 2016 3:55 pm
Less of a botnet then, nice.
What do caddies go for?
PostPosted: Sun Jun 05, 2016 5:54 pm
http://www.ebay.com/itm/NEW-Panasonic-T ... xywh1TBEfZ
This an outstanding price for a new caddy. Then you will need a hard drive.
PostPosted: Sun Jun 05, 2016 7:11 pm
And it's SHINY!
PostPosted: Sun Jun 12, 2016 2:16 pm
Disregard that 29, here's a cheap 19 Mk2! http://www.ebay.nl/itm/122006525572
Going with this me thinks, it even comes with a caddy+80GB HDD!
PostPosted: Sun Jun 12, 2016 2:50 pm
That's a good price for a complete unit.
I personally would check into a mk3 or later.
They are a better machine. They had Led backlight on the display and came with win7. Led backlight is much much better. Coming with win7 means you can get a factory recovery disk.
Model Number: CF-19FHGACAM
Status: DISCONTINUED
MSRP: $4,049
Description: WinXP (Vista COA), Intel Core 2 Duo U7500 1.06GHz (Centrino), 10.4" XGA Touch, 80GB, 1GB, Intel WiFi a/b/g/n, Dual Pass (Upper:WWAN/Lower:WLAN), TPM, Bluetooth, AT&T Cingluar HSDPA 3.6, No Drive
PostPosted: Sun Jun 12, 2016 3:03 pm
^the same dude also has a 19 Mk3 but it's in terrible shape, not bothering overhauling it.
EDIT: Or I might do it after all as it has GPS! Maybe make a beater out of it, dunno.
PostPosted: Sun Jun 12, 2016 3:55 pm
That mk3 is a GOOD unit to start with.
GPS
DUAL Touch
GOBI
Stylus included
Model Number: CF-19KDRCG6B
MSRP: $2,000
Description: WinXP Tablet (Vista COA), Intel Core 2 Duo SU9300 1.20GHz (Centrino2), vPro, 10.4" XGA Dual Touch, 160GB, 2GB, Intel WiFi a/b/g/n, Dual Pass(Upper:WWAN/Lower:WLAN), TPM, GPS, Gobi, Bluetooth, No Drive, Toughbook Preferred
PostPosted: Sun Jun 12, 2016 3:59 pm
GPS
DUAL Touch
GOBI
Stylus included
MSRP: $2,000
Meh, didn't do it in the end, 2 port covers missing, bad shape. If it was cheap then i'd snag it up but I have more important uses for my money this month. (grips, IFP+better damper internals for my Maverick DUC32's)
