It is currently Thu Mar 21, 2019 4:33 am
 Post subject: CF-29 battery
PostPosted: Tue Jan 12, 2016 8:41 pm
I have an extra CF-29 battery and I wa wondering if I can use it in my CF-30. It slides right in and the connectors look the same. Any thoughts?
We get some rules to follow.
 Post subject: Re: CF-29 battery
PostPosted: Wed Jan 13, 2016 10:58 am
Yes it should work. Slight differences in capacity, output voltage, charging current etc, but compatible.
PostPosted: Wed Jan 13, 2016 12:56 pm
Less capacity but yes, it'll work! :)
http://www.toughwiki.com
PostPosted: Wed Jan 13, 2016 1:53 pm
The 46 and 29 seem to work fine in a CF30 or CF31. The 65,71, and 72 work but the battery meter and run times get wonky. If one of those was the only battery I was using, it would probably be fine with a battery recalibration. But if I use a long runtime battery and then a short runtime battery, the laptop gets confused.
VZSU71 is 10.8v and 69Wh 6750 mah
VZSU65 is 11.1v and 56Wh 5.2Ah
VZSU29 is 11.1v and 6.6Ah 6600mah
VZSU46 is 10.65v and 8.55Ah
VZSU72 is 4500mah
VZSU72
Lightweight Battery for the Panasonic Toughbook 31 MK2 and Panasonic Toughbook 53 MK1, Genuine Panasonic Toughbook Replacement Battery
The CF-VZSU72U is the replacement Panasonic Toughbook Battery for Part Number CF-VZSU72
The CF-VZSU72U is the original battery that comes with the Toughbook 31 MK2 i3 only and the Toughbook 53 MK1 i3 only, the i5 Toughbook 53 and Toughbook 31 come with a 9-Cell battery and will not work with this battery.
VZSU71
Long Life Battery for Toughbook 52 MK4 and Toughbook 53 MK1, Genuine Panasonic Toughbook Replacement Battery for Toughbook 52 and Toughbook 53. The CF-VZSU71U replaces the Panasonic Toughbook Battery part number CF-VZSU71.
The CF-VZSU71U is the genuine Panasonic battery that comes with the Toughbook 53 and Toughbook 52, it didn't come with the i3 and p8600 of the 52, or the Toughbook 53 i3 but this battery will work with those laptops and increase the battery life compared to the original battery that came with them.
VZSU65
Lightweight Battery for the Panasonic Toughbook 52 P8400 MK2, Toughbook 52 i3 MK3 and Toughbook 31 i3 MK1 and MK2, Genuine Panasonic Toughbook Replacement Battery.
The CF-VZSU65AU is a lightweight (6-cell) battery, it comes standard on the Toughbook 52 P8400, Toughbook 52 i3 and the Toughbook 31 i3, the Toughbook 52 P8600, Toughbook 52 i5 and Toughbook 31 i5 Toughbook Laptops came with the 9-cell battery, this battery will not work on the i5 or P8600 Toughbooks. The CF-VZSU65AU replaces the following Toughbook Battery part numbers CF-VZSU65, CF-VZSU65U.
VZSU46
Long Life Battery for Panasonic Toughbook 30 MK3 (CF-30K) and Panasonic Toughbook 31 MK1 and MK2, Genuine Panasonic Toughbook Replacement Battery.
The CF-VZSU46AU replaces the following Panasonic Toughbook Battery part numbers. CF-VZSU46, CF-VZSU46U,
The CF-VZSU46AU is the original battery that came with the Toughbook 30 and Toughbook 31 (i5 units, the i3 came with the 6-cell battery, this battery will increase the capacity of the Toughbook 31 i3 models)
VZSU29
Long Life Battery for Toughbook 29, Toughbook 51, Toughbook 52 MK1, Toughbook 52 MK2 and Toughbook 52 MK3. Genuine Panasonic Toughbook Replacement Battery
The CF-VZSU29ASU is the replacement Toughbook battery for the compatible laptops listed above. With the Toughbook 52, the CF-VZSU29ASU is the same battery that came with the High End version of the laptop (a 9 Cell Battery), the low end version of the Toughbook 52 comes with a 6 Cell and this battery can be used as an extended life battery for the low end 52 as well.
The CF-VZSU29ASU replaces the Toughbook battery models: CF-VZSU29, CF-VZSU29AU, CF-VZSU29A
PostPosted: Wed Jan 13, 2016 1:59 pm
FYI,
I have 256 of these CF-VZSU29ASU batteries in stock - Brand new.
Give me an offer if you need some! :)
PostPosted: Wed Jan 13, 2016 2:05 pm
Thanks for the info, was curious, although if I sell the CF-29 it will go with both batteries.
