Light Scribe burner
Light Scribe burner
#1 Post by toughasnails »
Where is the best place and price to pick up a Light Scribe burner ?
Silver Trooper
Re: Light Scribe burner
#2 Post by Silver Trooper »
Do you want an internal to go into the CF-29 caddy, or an external? There usually are quite a few of either on Ebay at any given time.
#3 Post by toughasnails »
Silver Trooper wrote:Do you want an internal to go into the CF-29 caddy, or an external? There usually are quite a few of either on Ebay at any given time.
I would like to get one for the caddy but if I have too I will put it in my xps.I got the one below.
http://cgi.ebay.com/HP-DVD-RW-MULTI-DRI ... 4a9adec7a5
mrbungle
#4 Post by mrbungle »
I bought one on eBay for $9.99 and put it in my cd caddy. I loaded the drivers and it works perfectly.
CF-29H @ 1.4Ghz, CF-29 @ 1.2Ghz
w2ttt
#5 Post by w2ttt »
mrbungle wrote:I bought one on eBay for $9.99 and put it in my cd caddy. I loaded the drivers and it works perfectly.
So did this burner go inside your CF-29 CD Caddy and did it work well with both DVDs and CDs as you went about reading and writing them?
Gordon Beattie, W2TTT
W2TTT@ARRL.NET
#6 Post by toughasnails »
Mine works great , I put one in each one of my 29's and also my 18. I have burned about 80 cd's and 30 dvd's and only had 4 bad cd's.
