It is currently Sat Feb 16, 2019 10:42 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page 1 2 3 Next
 Post subject: Recovery Disks to USB
PostPosted: Tue Feb 10, 2015 1:06 pm
Greetings!
I am sure there has to be a way to merge the 3 recovery disks and make them bootable off of a USB. I can't find much information on the subject and was wondering if anyone here could shed some light. I have a CF-29L3Q71BE that I'm trying to fix and no DVD burner at my disposal. I was going to use my room mate's laptop to do the dirty work, but it has had a lot of issues and now is finally kaput, won't turn on. What luck, eh?
http://www.sevenforums.com/backup-resto ... s-usb.html
This is the topic I've been trying to piece things together from, but each time I try to boot up I get an error. Thank you in advance for any help you can offer.
PostPosted: Tue Feb 10, 2015 3:46 pm
I'm sure its been tried and someone will report back,if all else fails a cheap USB DVD drive might be the ticket. I'm assuming it would end up being a DOS boot USB. Strictly guessing here.
Also about $30 will score you the proper DVD drive for that 29.
PostPosted: Tue Feb 10, 2015 4:50 pm
I can't afford to upgrade my drive right now, but thank you for the feedback. I have very limited knowledge of DOS so fingers crossed someone reports back soon.
PostPosted: Tue Feb 10, 2015 7:29 pm
I am guessing this is your first Toughbook :) . Do you know what the restore disk are ? It's not like a windows disk, it is a image of your hard drive when it left the factory. It can not be done...sorry
If your friends laptop is the same as yours it would work but if it's different forget it. These disks will only work on your model (MK4) Does your disks say MK4 ??
Cel Google Pixel XL
PostPosted: Tue Feb 10, 2015 10:49 pm
As I suspected,bummer.
PostPosted: Thu Feb 12, 2015 2:56 pm
No, it is a crappy Toshiba. It has been having various issues for awhile now and I guess it finally bit the dust.
PostPosted: Thu Feb 12, 2015 3:09 pm
or you could maybe use 3 usb sticks???
That would be a new angle on it.
PostPosted: Thu Feb 12, 2015 4:32 pm
I'm trying to rustle up a third USB to test this out. I know there are several floating around somewhere... When I do find one, how should I load the .isos onto the USB?
PostPosted: Thu Feb 12, 2015 4:49 pm
google would be your friend
https://www.google.com/search?q=boot+is ... 8&oe=utf-8
PostPosted: Thu Feb 12, 2015 4:55 pm
Yeah, I tried those both already and still got errors.
