It is currently Tue Feb 19, 2019 10:06 am
PostPosted: Sun Feb 08, 2015 7:36 pm
Aight! So, I am the proud owner of a few 29's, some of which are giving me issues.
in this case, I have just put an OEM panny BT module in a 29ETKCZKM (that should have it anyway) but lack the proper OEM image for this particular MK2.
Does anyone know where the hell I can get the Panny OEM driver for this unit? All the official chanels I go to (panny websites) don't provide it, or I'm simply not "seeing" it. All I have is a hacked Toshiba stack, and I'm pretty sure that it's corrupt/malicious. I'm just looking for A2DP over BT.
TIA!
PostPosted: Sun Feb 08, 2015 7:52 pm
here..
http://toughbooktalk.com/public_downloa ... /TomCat57/
or here for direct link..
http://toughbooktalk.com/public_downloa ... 5243ya.zip
PostPosted: Sun Feb 08, 2015 8:08 pm
It should install after you update to XP Pro SP2
Cel Google Pixel XL
PostPosted: Sun Feb 08, 2015 8:32 pm
Aye, toughasnails, XP2+ will install the M$ stack for it, but not until you get a driver that works with the hardware "ugx" (correct me if I'm wrong, please)
And Shawn, I don't care what your wife said about you...or Tomcat, you're both aight with me!
Thanks, guys!
PostPosted: Mon Feb 09, 2015 4:23 pm
I had the same problem as you many years ago And Rob made that the fix a. sticky..first one at the top of this 29 forum
Cel Google Pixel XL
PostPosted: Wed Feb 11, 2015 10:14 am
I thought that I posted the Toshiba Bluetooth Stack here somewhere...
