Swapping Bluetooth
Swapping Bluetooth
#1 Post by toughasnails »
Is the bluetooth in the CF-29 removeable or is it built on the motherboard? It is installed in my 1.2 and would like to pull it and install it in my 1.4 . I tried to look it up in my service manual but it does not list a bluetooth.
Silver Trooper
Re: Swapping Bluetooth
#2 Post by Silver Trooper »
Removable, it goes on the same sled as the WWAN module. (If I remember correctly) I know the GPS and WWAN modules are on the sled for sure.
#3 Post by toughasnails »
Silver Trooper wrote:Removable, it goes on the same sled as the WWAN module. (If I remember correctly) I know the GPS and WWAN modules are on the sled for sure.
Are you talking about the sled that is on the left side above the battery held in with 2 screws. Mine did have it at one time but not now.
Silver Trooper
#4 Post by Silver Trooper »
Per Toughbook in the other forum:
"It should be all assessable by removing the hinge covers and keyboard... Just remember to REMOVE your battery first! (I know... It goes without saying... But you'd be surprised!)"
#5 Post by toughasnails »
Silver Trooper wrote:Per Toughbook in the other forum:
Great . I was wondering if it was their or on the bottom . I am installing the Emissive Backlit keyboard today so I should be able to do it too.
#6 Post by toughasnails »
Almost forgot will a hard drive door fit a PCMCIA door ...same?
Can't get mine off to check.
Will check back when I get up
tomcat57
#7 Post by tomcat57 »
I dont know Blair
What door do you need
Alex
#8 Post by toughasnails »
The PCMCIA door. They look the same.
tomcat57
#9 Post by tomcat57 »
If You are in no hurry I might have a spare
It might be a month before I get around to look for it as Its at my rental house basement
Let me know if you are not in a hurry
Alex
#10 Post by toughasnails »
No hurry at all. Its filled at the moment sd reader and the tray that holds 2 spare cards
Bedtime..later :zzz:
