It is currently Sat Feb 16, 2019 10:26 pm
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 4 Next
PostPosted: Mon Mar 11, 2013 6:28 pm
Hi i am new to the Website.......I just need to be put on the right Direction...On the Driver Installs Because i get a little Confused on the Panasonic Website....Would like what to all do first...It say's it has a Touch Screen in Bios but Idk about if it works....It has a Antenna On top.. Idk what that does...This is like My first Toughbook lol to fix.... xD....I have fixed,repaired 100s of laptops but this just makes me want to :blowaway: I Upgraded the Ram,HDD....I have fully installed Wins XP SP3.... Missing 5 Driver's in Device Manager it say's ...please Help or Point me to a Thread that i Overlooked while searching on Your Website Or Put it in this Thread ... Thanks!
PostPosted: Mon Mar 11, 2013 7:14 pm
Welcome to Toughbook talk.
Is this where you got the drivers http://www.panasonic.com/business/Toughbook/computer-support-search-downloads.asp . The model you have is a MK3 and from what I can see from your model number you have a retired SBC (AT&T) model which are known to have non working touchscreen. These were not looked after very good.
Which drivers are you missing
Something you should look into is the recovery disk (3 disk set). The disk are an image of the hdd when it left the factory so no loading of drivers...nothing. About 30-40 minutes and its all done...OS and drivers all loaded :D
SBC Toughbooks http://www.panasonic.com/business/toughbook/hotNews.asp
Cel Google Pixel XL
PostPosted: Mon Mar 11, 2013 8:19 pm
i looked on ebay for the disk set... Little high for my budget Atm... I been trying to figure how much A new Touch Screen Would be...And the Driver's I am missing are ...Multimedia Audio Controller,PCI Modem,Unknown Device,Video Controller,Video Controller(VGA Compatible)...Now What about the Antenna thing does that work still? Or no? :D Thanks for the help
PostPosted: Mon Mar 11, 2013 9:28 pm
Here is a good drive page to check out http://www.toughbookdrivers.com/drivers/cf-29/index.php?dir=CF-29%20MK3/ . He is a member of this forum too.
The antenna is for cdma and evdo modems I guess (Sprint or Verizon)...not much use now...
Cel Google Pixel XL
PostPosted: Mon Mar 11, 2013 11:25 pm
In Europe / Netherlands, i am able to use the antenna with the Vodafone network. I can send and receive SMS with my CF-28 with the Checknet Utility. Sometimes very handy when you are somewhere without any wifi or internet. Dont know if the CF-29 card is the same as the Cf-28 version.
If you see "Unknown Device" you have to install the hotkey driver for it.
PostPosted: Tue Mar 12, 2013 7:16 am
I actually sought out an SBC unit to transplant the antenna and LCD to my MK1 (the newer the MK, the higher NIT of the bulb, generally speaking), and I hooked it up to a sierra 860 gsm/3g card. Worked great.
Many of us are also over at NBR and we've put together a ton of useful resources.
Talk to Sadlmkr about getting your TS replaced or repaired.
If you want to do it yourself talk to techtuff about getting a new TS glass and check out my TS swap howto http://forum.notebookreview.com/panasonic/637315-cf-29-keyboard-touch-screen-glass-swap-walkthrough-pics.html
http://forum.notebookreview.com/panasonic/241106-cf-29-f-q-read-me-before-posting.html
http://www.toughwiki.com/index.php?title=CF-29
doing a search for your model# will go a long way, too! check it out
https://www.google.com/search?q=site%3Ahttp%3A%2F%2Fforum.notebookreview.com%2Fpanasonic%2F++29HTM50
Good luck!
ROB or mods, if I just did a nono, please let me know.
PostPosted: Tue Mar 12, 2013 10:49 am
Looks fine here...good show :cheers:
Cel Google Pixel XL
PostPosted: Tue Mar 12, 2013 12:13 pm
Looks real good, I.F.
I will take a computer and turn it around in two to three days. $50 minimum, extra for parts if needed. I have about ten used but good touchscreens in bezel but I can probably fix O.P.'s. which costs as I said $50 plus shipping both ways.
Part of this is I will factory restore the drive as this is a crucial part of the process.
PostPosted: Tue Mar 12, 2013 2:25 pm
I left that part out, but I"m a real big proponent of the OEM image CD's..... In lieu of that, I"m sure if the OP looks at those links I posted, they'll find a how to about the proper order of installation of said drivers.
PostPosted: Wed Mar 13, 2013 4:59 pm
I don't see anything wrong with the screen etc...just no touch... i have been very busy with work.... lately so i haven't got started downloading the drivers etc
