It is currently Tue Feb 19, 2019 9:35 am
PostPosted: Wed Aug 29, 2012 2:35 pm
Anyone have any idea what the part number would be for the little 3 pin internal mic connector in the CF-29? (I think it was CN23 inside)
I saw the thread where an internal electret mic was added. I want to add one to mine, I have an app that could really benefit from that. I have the mic elements, need the connector.
I verified it works, I injected a tone in the connector and it came through loud and clear.
Looks like it might be about 4mm across, but it is very small. Digging through my junkboxes and all I find are slightly larger ones, or ones with more than 3 pins. I might cut a 4 pin one wiht a razor knife to try to make it fit, but I was hoping someone would know.
PostPosted: Fri Aug 31, 2012 2:28 am
I heard this is same as the mic that comes in CF-28. I have one that I can disassemble this weekend . . .
Shoot me a PM if I don't post some info by Sunday.
PostPosted: Sat Sep 01, 2012 9:44 am
Yes! Its perfect much. No modification needed just plug in play.
PostPosted: Sat Sep 01, 2012 3:23 pm
did anyone try to add this or any other internal mic to a CF-30 (mk1+) ?
C1mk1&2, CF19mk4, CF30mk1&mk3
