It is currently Sun Feb 17, 2019 4:29 pm
PostPosted: Tue Oct 18, 2011 11:47 pm
good morning..
i hope my 29N arrives today. but as it have only a floppy i wonder how to install the 3 reccovery cd`s with a usb stick.
could i just copy the files from the cd`s over to a usb drive and its a go?
Panasonic Toughbook CF-29NTQGZBM, PM 1.6Ghz, 512MB, 80GB HDD.
Sony Vaio Z. i7 M620 @ 2.67Ghz, 8GB, 4X62GB Raid-0, Full HD 13.1"
PostPosted: Wed Oct 19, 2011 1:53 am
You will need a external cd-rom if you don't have a cd-rom caddy in your 29. Not sure if you know or not but the recovery disks are a image of the harddrive when it left the factory. You can get them for $40-$50 which is a good buy since they were about $75.00 a year ago.
Cel Google Pixel XL
PostPosted: Wed Oct 19, 2011 4:18 am
will get a external cd rom then. :) will buy a cf28 for parts, keyboard and cd rom later on. thanks.
any particular tips for first install of the system? anything to consider?
it is getting delivered today.. god damn im thrilled!!:)
PostPosted: Thu Oct 20, 2011 12:17 am
So what's it like ?
Cel Google Pixel XL
PostPosted: Thu Oct 20, 2011 1:04 am
well, first off. im shocked over it ruggedness.. its like no other thing i`ve tested. i swear i could use it as a crowbar if needed..
firstly the touchscreen did not work, so i googled alot and came to the conclusion that i needed to break it down. so completely took apart the lcd, cleaned and checked connections. voila, it worked again! hurray.. :)
other than that i`ve just installed updates like crazy. cant wait to get it up to date and get to use it in the garage, not worry about dust, metal spoon from the lathe etc. :)
but i wondered, when the wonderful TB is up to date with everything and i am happy with its configuration with essentials. how can i make a complete image of the hdd?
so when i want to upgrade the hdd, i could just copy the image over to the new hdd and be up and running.. any pointers here?
PostPosted: Thu Oct 20, 2011 2:07 am
I find this is the best out ACRONIS TRUE IMAGE HOME Any of the older ones should work for you but will not work on W7 machines.Check it out
norway ebay - http://search.eim.ebay.no/?kw=ACRONIS+TRUE+IMAGE+HOME&el=3&en=50&elc=3&ep=1&es=21
and USA - http://www.ebay.com/sch/i.html?_nkw=ACRONIS+TRUE+IMAGE&_sacat=0&_sop=15&_odkw=ACRONIS+TRUE+IMAGE&_osacat=0&_trksid=p3286.c0.m270.l1313
I paid about $20.00 USA money for the 2010 one. It's easy to use...I just used it on my GoBook the other day. I bought one 2 weeks ago and did all the updates then put my other harddrive in a external harddrive case and made a image of it then bought another GoBook and when it came I just dropped the harddrive in the caddy and I was up and running in 2 minutes :) . Not sure what it cost over on your side but it is well worth it. At one time they did have a 30 day trial. I will check
Cel Google Pixel XL
PostPosted: Thu Oct 20, 2011 2:14 am
Here is there web site
http://www.acronis.com/promo/atih2012/ATISpecific/?source=us_googleATI_b&c=6991643777&k=acronis%20true%20image&gclid=CJvo4qXn9qsCFYpn5Qode1iTHg
and at the bottom you will find the free trial.
Cel Google Pixel XL
PostPosted: Thu Oct 20, 2011 5:08 am
excellent, will give it a try.
do i need the acronis to unpack the contents of the hdd as well? or does it copy the contents between the hdd`s?
PostPosted: Fri Oct 21, 2011 2:03 am
It does everything for you, If you go to "Tools & Utilites" and click on clone disk. Thats what I do if I have 2 the same laptops, saves me the trouble of installing the OS and downloading all the updates twice.
Cel Google Pixel XL
