It is currently Sat Feb 17, 2018 5:01 pm
PostPosted: Thu Jan 29, 2015 12:08 am
Summary:
This security hole, which impacts many older versions of Linux and some current ones, should be patched as soon as possible.
http://www.zdnet.com/article/critical-linux-security-hole-found/?tag=nl.e539&s_cid=e539&ttag=e539&ftag=TRE17cfd61
Thanks to ajkula66 for the original post about this security hole.
CF-52GUN
PostPosted: Thu Jan 29, 2015 3:16 am
Morgan, thank you for this information.
I like the ending words of the article you linked: "My advice to you is to now, not later today, now, update your Linux system as soon as possible. After patching it, you should then reboot the system. I know for Linux it's rarely needed to reboot, but since gethostbyname is called on by so many core processes, such as auditd, dbus-daem, dhclient, init, master, mysqld, rsyslogd, sshd, udevd, and xinetd, you want to make absolutely sure that all your system's running programs are using the patched code."
Yes, we survived the storm. NJ & NY not as much as expected, home in RI much more. Judy cleared most of the mess yesterday, Saturday it will be my turn to finish up. :doh:
CF-53 MX-16
CF-30 MK2 SSD LMDE2 Betsy, MK2 Navigatrix, Fundraiser for TbT
CF-52 GUN SSD LMDE2 Betsy(NICE) Thanks Sadlmkr
CF-33 MicroWattR8 Thanks Springfield
CF-29 MX-16 (https://mxlinux.org/)
CF-28 MK3 MX-14.3 & MicroWattR8
PostPosted: Thu Jan 29, 2015 6:59 am
I've been patching servers all week over this. Some older ones are impossible to upgrade and are being retired.
