Updated SolydX - no FoxTrotGPS
I did the latest update to SolydX this morning, when finished I restarted the unit and went to fire up FoxTrot to download more maps. When I clicked on the menu entry for FT, I saw the program flash open, then immediately closed. Any one have a fix?
I don't have the time to search the Solyd forums. Trying to get 5 systems built before Fri, got 4 hrs sleep last night.
Any help is appreciated. Thanks.
Re: Updated SolydX - no FoxTrotGPS
First of all make a copy of your home directory ....maps should be in there and you don't want to lose them.
Then I would right click foxtrot and set as favorite again.
Could this be a permissions issue? Are you admin or custom in users and groups? I chose admin.
Could solydx have changed the way the menu is handled..or maybe it's buggy.
IOW I don't know but I'm thinking about it.
I am in the admin group.
I have over 7mil items, totaling over 5.8GB in my maps folder. It is backed up every night.
I will try those suggestions when I get time, maybe later tonight. Been at it since 05:30.
Thanks for the suggestions.
If you fire it up through the command line in a terminal, there's likely to be an error message displayed.
Here are the errors from terminal.
The autocentering bit is because I don't run the GPS if all I am doing is downloading maps at different levels of zoom.
I never did add FT to the favorites menu, hit the surrender key, tap accessories, tap FT. Surrender key=super key 'cause it looks like a waving white flag on the emissive kb of the 29MK4. Bill surrenders!
morgan@cf-29mk4tb:~$ foxtrotgps
(foxtrotgps:3136): Gtk-CRITICAL **: IA__gtk_toolbar_set_icon_size: assertion 'icon_size != GTK_ICON_SIZE_INVALID' failed
(foxtrotgps:3136): GLib-GObject-WARNING **: The property GtkDialog:has-separator is deprecated and shouldn't be used anymore. It will be removed in a future version.
REPOLIST == NULL
*** on_drawingarea1_configure_event():
pixmap created
Not autocentering map due to missing gps data
(foxtrotgps:3136): Gtk-CRITICAL **: IA__gtk_entry_set_text: assertion 'GTK_IS_ENTRY (entry)' failed
Attempt to unlock mutex that was not locked
Aborted
I like it. lol
This is the relevant bit:
From what I've read so far is that it's a recently discovered bug that has been filed upstream in Debian's bug track, so this is not specifik to SolydX.
I don't know much about this distro, but I would look into downgrading foxtrotgps or track down what other subystems were upgraded in order to make sense of how it broke in the first place.
Here's mine:
Running LMDE 17
(foxtrotgps:15942): Gtk-CRITICAL **: IA__gtk_toolbar_set_icon_size: assertion `icon_size != GTK_ICON_SIZE_INVALID' failed
REPOLIST == NULL
pixmap created
(foxtrotgps:15942): Gtk-CRITICAL **: IA__gtk_entry_set_text: assertion `GTK_IS_ENTRY (entry)' failed
connection to gpsd SUCCEEDED
Note GPSD succeeded. I have seen such entries before when running a GUI actuated program from Terminal. Not the fail one. Don't know why.....takes too much thinking.
What say to reloading foxtrotgps?
Running LMDE 17
REPOLIST == NULL
pixmap created
Heh, GTK related warning messages aren't all that unusual. Go ahead and re-install foxtrotgps if you wish, but like I said, if it were me I would look into seeing what was upgraded and follow the path to downgrading anything related to foxtrotgps application, data and gpsd. It's not a simple task, though.
I have Foxtrotgps working again. See this link:
http://forums.solydxk.com/viewtopic.php ... 461#p46461
