It is currently Sat Feb 16, 2019 3:56 am
 Post subject: VR-1 CPU?
PostPosted: Sun May 25, 2014 8:20 pm
Did the VR-1 come with Core Duo CPUs? If not, can I upgrade it to a core duo CPU?
I don't know the FSB. I found two online. The CPU is listed as unknown. The speeds are 2.0GHz and 2.2GHz.
I've Googled and can only find Pentium-M and Celeron models.
I purchased these believing they were Core Duo. I already have a Pentium-M 2.0GHz Toughbook. It'll be a huge let down if my VR-1 models are not Core Duo.
 Post subject: Re: VR-1 CPU?
PostPosted: Mon May 26, 2014 8:51 am
I think the VR-1 models are Pentium M only. I don't think they got core duo/ Core 2 duo until VR-2.
Alienware M11x R1
PostPosted: Mon May 26, 2014 9:46 am
VR 1 SPECS
VR 2 SPECS
PostPosted: Mon May 26, 2014 7:34 pm
I think you need to check out this thread http://www.toughbooktalk.com/viewtopic.php?f=32&t=1006
Quote:
. Now! here is the good news it is socket type with PGA479M socket. It means it can upgraded like the cf-51. I say the best CPU for this is the T7600 but a bit pricey. I don't have spare right now but I will borrow the one on CF-51 with 2.0Ghz. Remember only with the 667Mhz fsb. Let see how it perform. Anyway, this also can be upgraded to 4gb RAM
Cel Google Pixel XL
PostPosted: Mon May 26, 2014 7:50 pm
That is the XR-1, I think it started it's series with the Core Duo, not Pentium M.
Alienware M11x R1
PostPosted: Mon May 26, 2014 8:03 pm
Does the VR-1 have the PGA479M socket?
PostPosted: Mon May 26, 2014 8:06 pm
I have two CF-51 I'll be upgrading to Core Duo someday. Is there a hardware maintenance manual available for the VR-1 so that I can upgrade it to core duo?
PostPosted: Mon May 26, 2014 9:09 pm
Pentium M can't be upgraded to Core Duo, the socket is incompatible, the Mk3 and Mk3LL CF-51 came from the factory with core duo, the Mk1, Mk1LL, Mk2 and Mk2LL came from the factory of Pentium M.
Alienware M11x R1
PostPosted: Tue May 27, 2014 12:47 am
And if they are 2.0 Pentium M it will be a waste of time kicking that one up,it goes 2.0,2.13 and 2.26 I believe and there won't be a big improvement. The 2.26 was hard to find at one time. :D
