Does anybody know why Panasonic modified the rear case with a new cover?
https://i.imgur.com/iUr6phI.jpg
							FZ-G1 Mk4 rear case
FZ-G1 Mk4 rear case
Regards.
						Re: FZ-G1 Mk4 rear case
Because that's where the insertable SCR or RFID or UHF RFID reader would go if that G1 had it.
Do you have a picture of a mk4 with any of these options installed?Rob wrote:Because that's where the insertable SCR or RFID or UHF RFID reader would go if that G1 had it.
Just out of curiosity.
Regards.
So they use more screws to attach the smartcard reader, don't they?
							Regards.
And the fact that the G1 Mk4 has a M.2 SSD instead of mSATA.Rob wrote:Because that's where the insertable SCR or RFID or UHF RFID reader would go if that G1 had it.
Do you know which ssd model they mount?User32 wrote:And the fact that the G1 Mk4 has a M.2 SSD instead of mSATA.Rob wrote:Because that's where the insertable SCR or RFID or UHF RFID reader would go if that G1 had it.
Regards.
My Mk4 had a Toshiba 128GB SSD, not sure of exact model.rrtek wrote:Do you know which ssd model they mount?User32 wrote:And the fact that the G1 Mk4 has a M.2 SSD instead of mSATA.Rob wrote:Because that's where the insertable SCR or RFID or UHF RFID reader would go if that G1 had it.
