FZ-G1 swap MC8305 for MC7750
I currently own a FZ-G1 that has a MC8305. I would like to switch it to a MC7750 for Verizon 4G LTE. Is there anything in particular I need to look out for? I see some people saying things about laptop-manufacturer branded cards vs unlocked. I'm not sure what applies to me.
Chris
Chris
Re: FZ-G1 swap MC8305 for MC7750
Get a card from a Panasonic.. Nothing else will work.
I hope the OS / firmware recognizes the different card. Can't know this until you try it.
Give us your full model number and shout HEY ROB! This is one thing he KNOWS.
Welcome to the madhouse. BTW ROB owns the forum. Thanks for the help Rob and welcome to the forum Chris. Also what OS are you running?
Jeff.....all else fails call the phone number....
Thanks for the warm welcome guys! Yes I did speak with Rob via e-mail. Going to get a quote from him to see how much it would be. Got the unit off of ebay, seller said it had a wwan card but didn't specify (and at that time wasn't planning on using wwan).
FZ-G1AAAFECE running Windows 8.1 Pro
Interesting... just because I can I pulled the battery out. Just noticed under the battery is a different Model number. That one says FZ-G1AAAZXZZ. Serial number is off by one character in the middle ( 's' vs 'a'). Hmm...
PC Information Viewer states info I originally posted.
FZ-G1AAAZXZZ
Usually the numbers with Z's at the end are "base unit" numbers. The number gets changed with the added options
YIKES.... This is a pre-production model......... Yes, the models get changed.... I can't believe the S/N is off though.... That's a RED FLAG for other things....
Rob, can I ask you what you mean with "RED FLAG for other things"?
Regards.
He shouldn't have that computer.....
dun dun!Rob wrote:He shouldn't have that computer.....
