CF19 Keyboard Install
Iceman304
#1 Post by Iceman304 »
Finally picked up a CF19. I also have an illuminated rubber keyboard. Could anyone provide some insight on install procedure? Any help would be greatly appreciated.
Re: CF19 Keyboard Install
#2 Post by toughasnails »
I do not own a 19 but if I am right its no different than the 18 and it only took about 20 minutes to install. I just checked the service manual for 19 and it looks the same as the 18. Just take your time when removing your old keyboard because they stick it down with double face tape. and don't forget to take out the battery.....hate to see you fry it before you get to use it Do you have the service manual for your 19? What is the full model #
Might try to post next time here "CF-19 talk" since only the hidden group can see this post :)
viewforum.php?f=3
#3 Post by Rob »
I've moved it to the CF-19 forum... should get more attention here.
Iceman304
#4 Post by Iceman304 »
Rob wrote:I've moved it to the CF-19 forum... should get more attention here.
Thanks Rob.
