Cf-19 mk 5
Cf-19 mk 5
Hi guys not been here for a long time but just picked up a couple of used cf-19 mk 5 laptops
Does anyone know how to boot these machines to see if they still have the factory recovery partition ?
Or anyone know where I can get a ISO of the Panasonic install disks to use with the windows key ?
Thanks in advance
Thanks in advance
Re: Cf-19 mk 5
If you bought it from a reseller then my guess the HDD has been whiped clean. If you get the recovery disc (2) you won't need the COA on the bottom. It is different than the one that the recovery disk loads. Where do you live ? USA, Canada
Blair
Re: Cf-19 mk 5
Boot to BIOS
Navigate to last page
Post a photo of that page
Re: Cf-19 mk 5
New zealand
Will post a pic when they arrive should be about 4 days
Re: Cf-19 mk 5
I don't have a Toughbook near at the moment.
I think different models may call it by a different name.
If the partition is there, the menu item will be there. But most of the time, Ebay units have the entire drive wiped.
According to a manual....
Press F2 or Del while [Panasonic] boot screen is displayed.
The Setup Utility starts up.
If the password is requested, enter the Supervisor Password.
Select the [Exit] menu, then select [Recovery Partition] and press
Enter
Enter
Re: Cf-19 mk 5
I found a video for a CF 53. The CF19 should be very similar.
https://www.youtube.com/watch?v=DLASUUFAoxE
Re: Cf-19 mk 5
Ok guys
CF-19AMNL7PA
next question none show a wireless available even with my wi-fi enabled
I have turned wi-fi on
What should I see in system properties if my wifi drivers are loaded and if not which drivers di I need ?
Win7 64bit
CF-19AMNL7PA
Win7 64bit
Re: Cf-19 mk 5
Could it be that no wireless card is installed? Government issue?
Take a peek at Concealed Mode Configuration on bios MAIN page also.
Re: Cf-19 mk 5
Grrrr stelth mode requires a supervisor password
I don't suppose anyone knows the default one or a work around ??
