It is currently Thu Jul 19, 2018 4:56 pm
PostPosted: Wed Sep 06, 2017 7:05 pm
Hello,
Has anyone installed windows 7 64bits on a mk3? If so, where did you get the drivers? as I can't find them.
Regards.
PostPosted: Thu Sep 07, 2017 1:37 am
I used to run win8.1 64bit on a 19mk3 without any additional drivers. worked fine.
PostPosted: Thu Sep 07, 2017 3:51 am
http://business.panasonic.com/support-c ... rdownloads
Scroll down to 64 W7. Download and run as ADMINISTRATOR.
PostPosted: Thu Sep 07, 2017 4:28 am
here
ftp://ftp.panasonic.com/computer/softwa ... 3-7x64.exe
PostPosted: Thu Sep 07, 2017 6:36 am
Thank you all. :pbjt:
Strangely enough, I can't find them in the global support site (http://pc-dl.panasonic.co.jp/itn/default.html)
Regards.
PostPosted: Fri Sep 08, 2017 10:02 am
Well, I have a problem with the 3g module, I think it's a gobi1000, I have the drivers but don't work, I think they are 32 bits only.
Any idea to make it work on windows 7 64bits?
Regards.
PostPosted: Fri Sep 08, 2017 12:16 pm
What is the second line under the properties tab in DEVICE MANAGER [COM 3].
250d is Gobi 1000
250e is Gobi 2000
If I was running a Windows machine I would send a picture.
Here's a sample from search on Notebookreview. You need to do some reading.
http://forum.notebookreview.com/threads ... ed.494537/
Quote:
You could search for CF-19MK3 Gobi.
I tried it and there is three pages of posts.
This (Toughbooktalk) site has a search also.
Time to feed the sheep.
Good luck
PostPosted: Mon Sep 18, 2017 2:35 pm
rrtek wrote:
Hello,
Yes. Many, many times. I've been using a flash drive from a co-worker and I think he used vista drivers. I can ask him where he got the drivers if vista ones don't work.
PostPosted: Mon Sep 18, 2017 3:54 pm
Shawn wrote:
Matt,
Thanks for your post.
You may have missed the link I posted.
Here are the proper drivers direct from Panasonic.
PostPosted: Sun Oct 01, 2017 7:38 pm
It ends with 250c. According to the device manager is a Gobi HS-USB.
Regards.
