It is currently Wed Jan 23, 2019 5:57 am
PostPosted: Tue Apr 26, 2016 5:28 pm
WTF Panasonic?! http://forum.notebookreview.com/threads ... t-10205076
Tell me that guy is only joking and it has two RAM slots?
Having just brought a 19 Mk6 (waiting on it to be shipped) and finding this out made me a little :mad: inside.
PostPosted: Tue Apr 26, 2016 7:30 pm
It depends on the model. If your model has an option for Camera. Then it has only one slot of RAM.
PostPosted: Wed Apr 27, 2016 5:09 am
Oh, thank god. I knew the Camera equipped models had 1 RAM slot but still.
PostPosted: Fri Apr 29, 2016 1:36 pm
I can confirm that the non-camera Mk6 has two ram slots, like all other cameraless 19's.
PostPosted: Wed Aug 23, 2017 3:16 pm
Like others said, if it has a camera then there is only 1 RAM slot. Have you got it yet? Not to worry you, but it's possible there was a camera but the seller removed it, leaving you without a camera and with only 1 RAM slot. A good way to check is if there's pictures of the one you bought, it will have a camera lens on the bottom of the toughbook.. but it's also possible this cover was replaced with a different cover. Either way, you could just get a 4GB stick of RAM (which is plenty for a toughbook) so it wouldn't be the end of the world. Hope this helps.
