It is currently Mon Jan 21, 2019 8:12 am
PostPosted: Wed Mar 02, 2016 4:17 pm
hi guyz,
got a few CF-19KDRAX6M
unable to install a gobi card on this.
when gobi 1000 installed, it DOES NOT show up in bios
when gobi 2000 installed, it DOES NOT show up in bios
when mc8700 installed, IT DOES NOT show up in bios
when installed on CF-19KDRAG6B, gobi cards show up in BIOS.
any tips guyz ?
[size=200]kindly email
MYDEARCOMPUTERS@HOTMAIL.COM
OR CALL CELL 630 290 1727
address: 720 S main street
Lombard IL 60148 USA.
REGARDS
MATT
[/size]
PostPosted: Thu Mar 03, 2016 12:54 pm
You might need to enable it by running a small software program called SPGOBI2. I have had to do it on a CF-19 and a CF-31 before.
CF-52GUN
PostPosted: Thu Mar 03, 2016 1:00 pm
Morgan,
Nice to see you back..
I checked into spgobi and I found a post that said it was for a mk4. Maybe that post was wrong.
I will PM a link. Please post your results
PostPosted: Thu Mar 03, 2016 6:15 pm
hi guyz, thanks for the tips
here is how it got solved.
took the machine CF-19KDRAG6B , where wwan card (gobi) was showing up in the bios
took out the WWAN/USB card out of the above machine along with the gobi card
installed it in the CF-19KDRAX1M powered up and there you go.. BAAAM!!! (all this time, the wwan was NOT showing up in the BIOS , but now, there it is ) . right there, wwan (gobi) showing up in the bios.
and the WWAN /USB card , which came out of the CF-19KDRAX1M , installed in the other machine *(CF-19KDRAG6B ) AND BAAM!!!! wwan shows up in the bios .
solution found by gods grace.
sharing this post out here. so that some one out there can do this procedure and get a solution.
REGARDS
MATT
[/size]
PostPosted: Thu Mar 03, 2016 7:01 pm
abcdcomputers wrote:
[size=150]
CTRL-PLUS to zoom. Please.
PostPosted: Fri Mar 04, 2016 4:55 pm
Thank you Shawn, it is good to be back. What an adventure. Managed to get out with my dog, both trucks, my bike (still a basket case), the water logged 52GUN and a couple bags of clothes. :|
CF-52GUN
