It is currently Tue Dec 10, 2019 7:10 am
 Post subject: Gobi 2000 activation
PostPosted: Thu Jul 09, 2015 2:13 pm
Hi I have a cf-19(cf-19RHRAG1M) with Gobi 2000 and cannot find a sim card to activate it. I checked with Verizon and Sprint and they don't have cards anymore so how can I get this to work? In the connection it shows Verizon Wireless under mobile broadband.
Thanks for the help
Gale Lee
 Post subject: Re: Gobi 2000 activation
PostPosted: Thu Jul 09, 2015 3:24 pm
What operating system? W7?
In device manager are you showing several Gobi entries?
Are you running VZAM? I'll see what my MK3 CF-30 looks like in a while.
Did you install the Gobi card and are you sure it's a Panasonic card?
PostPosted: Thu Jul 09, 2015 4:31 pm
Thanks for the reply. Answers in order of questions:
1 Win7 64 bit
2 Yes in 4 places
3 Yes
4 Yes this MK4 came with Gobi 2000 from the factory
Gale
PostPosted: Thu Jul 09, 2015 4:49 pm
Guys,
Stop.
This is a 3G ONLY card. Their are no 3G SIM cards for VERIZON OR SPRINT as they are CDMA. Only time you would need a SIM for 3G is for AT&T which you are not using.
You have to contact Verizon and give them the valid IMEI and MEID number from the VZAM software and they can activate it for you!
http://www.toughwiki.com
PostPosted: Thu Jul 09, 2015 5:01 pm
Thanks Rob, I knew there had to be an easy way!
Gale :clapping:
PostPosted: Thu Jul 09, 2015 5:07 pm
Thanks Rob.
