Not able to find drivers for my paticular model number
Re: Not able to find drivers for my paticular model number
#11 Post by SHEEPMAN! »
For most touchscreen equipped units you want the Vista drivers for Windows7 (I said most :)) So try the 19M. oops! Checked again and K/L has Windows 7 32. That may work.
Might and may are not encouraging words. Maybe someone has a 19P running W7. Kerry is right on the missing drivers. (safn1949)
The other one is the smartcard?????
safn1949
#12 Post by safn1949 »
You are going to have to go thru the device manager to install the hot key and misc driver,right click,update driver and then point it to the correct folder until it grabs it.
CF-19's are a LOT easier if you buy the restore disc,best money spent. My first one was a mk1 and I couldn't make it right to save my life,didn't have a clue. Restore disc,USB DVD drive and 15 minutes.....done deal.
