It is currently Wed Jan 23, 2019 12:15 pm
PostPosted: Fri Sep 12, 2014 9:29 am
I've just brought one of these and it works a dream :pbjt:
I've got a sweet 3G connection and crucially this device has also given me GPS which I have been trying to achieve for a long time with a Gobi2000 card but hit a brick wall so many times.
Only problem is now the GPS does take a while to get a fix and even when it does it is a very weak one outside and a fix inside is impossible. My question is, is there anyway to improve the signal?
I've heard that a separate Wi-Fi antenna can be installed purely for GPS receiving?
Please help guys
PostPosted: Sat Sep 13, 2014 8:47 am
Why not just install a original GPS unit for a CF19?
PostPosted: Sat Sep 13, 2014 10:12 am
I suppose you're looking for something like these:
http://www.ebay.com/itm/15-15mm-GPS-ant ... 4d0c4fd59d
http://www.ebay.com/itm/NEW-GPS-Antenna ... 35da4b137b
Not sure about the quality of these particular items, just did a quick search.
PostPosted: Tue Sep 16, 2014 2:39 pm
That looks just the job!!!!! Is it the Aux or the Main that I would be connecting the aerial to?
PostPosted: Wed Sep 17, 2014 7:25 pm
I don't know anything about your particular card but technically it should be 3G on Main and GPS on Aux.
