Has anyone got the front panel buttons working?
The only ones that work on mine are the 2 brightness adjusters and the "Windows Security" key right at the end on the far right which gives me Task Manager etc etc
I can't get keyboard or screen rotation to work and I don't know what the circle with the dot in the middle is for.
Windows 8.1 Pro on CF-19 mk3 (WORKING!)
Re: Windows 8.1 Pro on CF-19 mk3 (WORKING!)
Screen rotation will only work if you install official Panasonic drivers.
Lets's swap laptops!! I have rotation AND keyboard working... but my Video Controller still has the ! beside it in Device Manager so I can't get external video or mirroring to work. The only way to get external video is from the BIOS switched to External.
I've tried every Intel driver already... including all the ones for the 4-series chipset. I can't get it to install either via setup.exe, Device Manager>Update Driver nor the forced "Have Disk" method!
![Image](http://i.imgur.com/uf7JH8Jl.jpg)
