CF-19 Mk3 Win7 - Front Panel Buttons and Screen Rotate
Banshee
#1 Post by Banshee »
Has anyone got this working?
This is all I have left to fix and then I am confident that I have a fully working Win7 Mk3
I finally got the screen calibration working last night :D, turns out the drivers that were installed as part of the recover disk image were incorrect and wouldn't allow the calibration utility to work correctly, I was hunting around the web and eventually ended up at Fujitsu's own website, downloaded a driver package, installed it, and then found that the panel installed itself as a Fujitsu Touch Input (USB).
Ran the calibration utility and hey presto :headbang:
Just need to purchase a Gobi 2000 now so I can use the internal GPS and also utilise a PATG SIM with data on for occasional web use out and about when there is no Wi-Fi access :clapping:
