CF-19 WWAN Question
CF-19 WWAN Question
#1 Post by ADOR »
My CF-19 MK1 came in today. I still need to round up a few things for it, but I was comparing it side by side with one of my CF-18's. Does the CF-19's with WWAN have any kind of external switch to turn it on and off like the CF-18's do? Just thinking about my upgrades right now.
Re: CF-19 WWAN Question
#2 Post by Rob »
No, only way to disable/enable it semi-permanently is via the BIOS.
#3 Post by ADOR »
Thanks Rob, This will help in my decision later on if I want to upgrade to wwan, gps, rubber keyboard later on, or just get a different unit with this already installed.
db04p71
#4 Post by db04p71 »
ADOR wrote:My CF-19 MK1 came in today. I still need to round up a few things for it, but I was comparing it side by side with one of my CF-18's. Does the CF-19's with WWAN have any kind of external switch to turn it on and off like the CF-18's do? Just thinking about my upgrades right now.
Yes, the CF-19 has a wireless switch inside the door on the left side. My CF-19 Mk2 has this switch and I would assume the Mk1 does also. It controls all wireless functions, WWAN, WLAN and bluetooth. All ON or all OFF. The wireless switch utility, in the taskbar, let's you decide which function is on or off.
Glen
