It is currently Tue Feb 19, 2019 9:28 am
 Post subject: CF-31 LCD harness
PostPosted: Fri Apr 17, 2015 7:08 pm
I am in dire need of the LCD harness for a CF-31B,cash in hand,new or used.
 Post subject: Re: CF-31 LCD harness
PostPosted: Fri Apr 17, 2015 7:23 pm
Houston, We have a problem.....
That will keep your LEM from landing on the moon...
DFJS1233ZA LCD CABLE
PostPosted: Fri Apr 17, 2015 7:56 pm
Just wondering but did you check and see what a CF-30 harness looks like ?
Cel Google Pixel XL
PostPosted: Fri Apr 17, 2015 8:08 pm
This is LED,I'm going to order it Monday from Heartland,got to get this fixed for the guy asap.Thanks Shawn!
PostPosted: Fri Apr 17, 2015 8:11 pm
CF30 is probably a no go....
Does Cf31 have LED backlight? CF30 does not....
Lemme ck numbers...
CF30K mk3.... DFJS1031WA LCD CABLE
Different part
PostPosted: Fri Apr 17, 2015 11:17 pm
I swear I can't believe how stupid some people are,this has 160 hours on it and some dummy yanked the connector off,then put it back with a strip of scotch tape.I sent Tina Fasone at heartland an email with the order,easy fix but holy cow. :confused:
