It is currently Wed Feb 20, 2019 5:58 am
Post new topic  Reply to topic  [ 25 posts ]  Go to page 1 2 3 Next
 Post subject: New LCD for CF-31!
PostPosted: Thu May 22, 2014 3:16 pm
I've had it! I love my CF-31 but I can't stand this 1024x768 resolution much longer! Does anyone know of LCD's I can "swap" out? I'm not going to be too upset if I end up losing the touch screen in the process.
-Claes
There can only be one!
 Post subject: Re: New LCD for CF-31!
PostPosted: Thu May 22, 2014 4:46 pm
Well, I doubt it. I know on a cf52 the resolution is locked into the BIOS.
PostPosted: Tue May 27, 2014 12:53 pm
I'm an idea man, I thrive on enthusiasm! I don't need your negativity Shawn :-P
Hmmm, I feel like there's got to be a way! This resolution is driving me nuts!
-Claes
PostPosted: Tue May 27, 2014 12:55 pm
Might I suggest this? http://home.howstuffworks.com/hammer.htm
http://www.toughwiki.com
http://www.robsnetworks.com
http://www.giganethosting.com
PostPosted: Tue May 27, 2014 2:33 pm
It is "possible" just not simple. You'll need to edit the bios and change the resolutions. Then get a better screen and see if it works.
Simple way......sell the cf31 and buy a cf53...
PostPosted: Tue May 27, 2014 2:40 pm
I like this. My thought exactly. But then again I never did anything the simple way in my life. :D
Wanna trade? :swords:
PostPosted: Tue May 27, 2014 3:06 pm
I also have a 52 with a new WUXGA 1920x1200 screen,2.4cpu with 4000 hours but that's probably not fast enough for you.But boy does that new screen look beautiful. :boing:
PostPosted: Tue May 27, 2014 3:59 pm
I believe the CF-31 will run an external monitor at higher resolution. If it will and you can find a hi-res display panel that fits the case, you might hook it up internally to the external monitor port. If the built-in touchscreen won't calibrate to the new display you might have to get another touch panel and connect it internally as if it was a USB touchscreen for the external (internally connected) display.
PostPosted: Tue May 27, 2014 4:50 pm
Talk to Onakriss...
He's the one who modded the cf52 BIOS's to bypass the whitelist.....
I tried but met with fail...
PostPosted: Tue May 27, 2014 4:54 pm
Model Number:
CF-53SULCLLM
Status:
CURRENT
MSRP:
$3,309
Description: Windows 7 Professional (with Win 8 COA), Intel Core i5‑3340M 2.70GHz, 14.0" HD Touchscreen LCD (800 nit), 500GB Shock‑mounted HDD (7200rpm), 4GB, Wi‑Fi, Bluetooth, 4G LTE Multi Carrier, GPS Receiver, Dual Pass (Upper WWAN / Lower GPS), DVD Super MULTI Drive, TPM 1.2, Backlit Emissive Keyboard, Toughbook Preferred
High Definition (720p) LED 1366 x 768
