It is currently Tue Feb 19, 2019 11:25 am
 Post subject: Win 8.1 on CF-31SPLAX1M
PostPosted: Mon Apr 28, 2014 8:48 am
Hey guys, we installed win 8.1 on a CF-31SPLAX1M and now the touch screen wont work at all, and neither will the calibration utility. I've reinstalled what drivers I could, but it hasn't helped. It works in "touch mode" (through the BIOS) but it doesn't register about an inch around the edge of the screen.
If anyone has ran into a similar problem and has a few ideas, I would greatly appreciate it.
PostPosted: Mon Apr 28, 2014 11:16 am
This is a guess but the times I ran into that it was a bios problem. Mind you it was a 30 not a 31 but the wrong bios does that. Also happened this weekend and a reinstall fixed it,again on a 30.
PostPosted: Mon Apr 28, 2014 11:18 am
I'll give a reimage a shot and post the results, thanks.
*Edit - No dice. I'm thinking the BIOS. Anyone have any other ideas?
PostPosted: Mon Apr 28, 2014 6:42 pm
There doesn't seem to be any info on w8.1 on the Panasonic site, but there is some on upgrading from W7 to W8 as well as info on clean install of W8. Can't hurt to check it out.
http://www.panasonic.com/business/toughbook/computer-support-search-downloads.asp
http://pc-dl.panasonic.co.jp/itn/support/win8info31.html
CF-52GUN
PostPosted: Mon Apr 28, 2014 7:44 pm
Try installing win8 upgrade over a good working install of win7
PostPosted: Tue Apr 29, 2014 9:15 am
This unit isn't designed to run Win 8...
http://www.toughwiki.com
http://www.robsnetworks.com
http://www.giganethosting.com
PostPosted: Tue Apr 29, 2014 2:26 pm
I CAN DREAM, darnit! hahaha
Yea, i figured as much. Oh well. Thanks everyone for the advice!
PostPosted: Tue Apr 29, 2014 4:11 pm
According to the info in the second link I posted above the CF-31S is supported doing an upgrade from W7.
"Perform an installation (upgrade) with no peripherals connected
Object models: TOUGHBOOK CF-31S, CF-31U and CF-31V series"
CF-52GUN
PostPosted: Thu Jun 12, 2014 4:20 am
I did a win8 upgrade from win7, then upgrade to win8.1 on my CF-31Q without any problems, all functions work great.
CF-31 mk2 ToughBook, 320Gb 7200 rpm hdd, Win 8 Pro, Upgrades = 8Gb Ram, Super Multi Drive, Desktop Dock, Media bay battery, Emissive Keyboard, 128Gb SDHC.
More upgrades to follow, ie. GPS, USB 3.0 PCMCIA card & SSD.
JT-B1 ToughPad, WiFi, Android 4.0 powered, 16 Gig RAM, 32Gig SDHC
http://toughbooktalk.com
http://www.sevenforums.com
