It is currently Sat Feb 16, 2019 3:58 am
PostPosted: Mon Mar 07, 2016 12:55 pm
CF-W5 1.06 Dual Core XP Hold Out ~ moving to Win7 with a PATA SSD
Will the IDE SSD drive work????
Anyone have success?
If so what worked for you? What didn't?
CF-74's - 2
CF-W5's - 3
CF-52's - 4
Small Block Chevys -5
PostPosted: Mon Mar 07, 2016 2:15 pm
Make sure a 3rd part TRIM support is working as there is no garbage collection on IDE!!!
If not it will work for a bit of time then crash and burn and your SSD will be fried!!!
http://www.toughwiki.com
http://www.robsnetworks.com
http://www.giganethosting.com
PostPosted: Mon Mar 07, 2016 2:42 pm
"3rd part TRIM support" I'll look it up ;)
CF-74's - 2
CF-W5's - 3
CF-52's - 4
PostPosted: Tue Mar 08, 2016 2:38 pm
I am working on some W5's and my last T5 now. Dual cores and single cores. I got the single core windows 7 install down to around 25 processes after start up. It only has 1gb of ram. A guy here at works wants it for checking his deer cameras.
I do plan to try out two SSD's when I get home to see how they run in them before I sell them all. One is fullsized case 2.5" ide to Msata adapter with toshiba 128gb Msata ssd. The other is the half length ide to msata adapter(this one I know works, but speed is slower than I want).
Alienware M11x R1
PostPosted: Fri Mar 11, 2016 6:19 am
Let me know your success on the W5.
CF-74's - 2
CF-W5's - 3
CF-52's - 4
PostPosted: Fri Mar 11, 2016 1:44 pm
I will let you know.
Alienware M11x R1
PostPosted: Wed Mar 16, 2016 11:02 am
I picked up a new 120g 5400 for song. I'll save the last unit for the SSD & follow the leaders.... ;)
CF-74's - 2
CF-W5's - 3
CF-52's - 4
PostPosted: Wed Mar 16, 2016 11:46 am
I only got a week left till I head home, so in a week and half to two weeks I should have had time to test it out.
Alienware M11x R1
PostPosted: Sat Mar 19, 2016 4:22 am
Opps CF-W5 can't install 64 bit? .... 32 on the way.
CF-74's - 2
CF-W5's - 3
CF-52's - 4
PostPosted: Sun Sep 18, 2016 2:53 pm
Did you ever ssd a w5?
CF-74's - 2
CF-W5's - 3
CF-52's - 4
