It is currently Sat Apr 20, 2019 4:44 pm
 Post subject: WWAN/GPS card For a C1A?
PostPosted: Sun Dec 07, 2014 4:23 pm
Guy wants to know if I can add GPS to a CF-C1ADAJZ1M,is there a card that will work? :D
PostPosted: Sun Dec 07, 2014 5:38 pm
http://www.ebay.com/itm/Qualcomm-Sierra ... 43d1fafbd1
Ok,this appears to be the card,I see nothing in the bios for wwan/gps so I need one of you gurus to tell me if and how it works. Cuz I don't have much of a clue. :D
PostPosted: Mon Dec 08, 2014 6:06 am
When you install the Gobi driver from Panasonic, it will open another com port that shows NMEA. That is the GPS port. A GPS tool like Leadtec's Navigator should show data on that com port at 4800 baud.
PostPosted: Mon Dec 08, 2014 12:46 pm
Thanks for that,seems easy enough.
