It is currently Mon Jan 21, 2019 8:19 am
PostPosted: Sun Jan 20, 2013 5:27 pm
I've a CF-17 Mk 1 running XP. Decided I should up grade the bios to cfm34_mk1_w2k_v151l15.exe (V151l15). There seems to be a companion piece of software called "EC upgrade for Windows 2000. Use with CFM34_mk1_w2k_V151l15.exe BIOS upgrade. Version: L0111120. " I've no idea of what the "EC" is nor how to install this software.
A second issue is that when I attach the CF-17 to a CFVEB341 docking station, COM1 (on the CF-17) goes dead. Is there some way to have both COM1 (on the CF-17) and COM2 (on the docking station) working at the same time?
thanks for any insights, -john-
PostPosted: Tue Jan 22, 2013 8:15 am
Be warned ! If you install the wrong BIOS, your CF-17 turns into a doorstop/brick.
the EC update must be performed first ! After the EC update you can update your BIOS. Otherwise , your machine wont boot.
PostPosted: Wed Jan 23, 2013 2:56 pm
You have my attention! Is the EC software install from DOS like the BIOS upgrade? And, what is the EC software?
thanks for your response, -john-
PostPosted: Wed Jan 23, 2013 3:06 pm
Concerning getting two com ports running simultaneously: My earlier description of the problem was incorrect. Once again, I'm running XP with SP2.
When I start the CF-17 Mk1 some process is grabbing COM1, making it unavailable. If I have the 17 plugged into a docking station I can use COM2, but COM1 remains unavailable.
One partial work-around is to go to Device Manage and disable COM1 and then re-enable it. COM 1 then becomes available for use (along with COM 2 if I'm plugged into the docking port).
Anybody have any ideas about what process might be grabbing COM1 during start up?
thanks, -john-
PostPosted: Wed Jan 23, 2013 4:37 pm
Serial Port.
PostPosted: Wed Jan 23, 2013 6:35 pm
Yes, I talking about the the RS232 serial ports.
PostPosted: Thu Jan 31, 2013 4:38 pm
Just an update on the problem using two comm ports: Turned out I had a printer installed and had configured it to use COM1. When the system booted it grabbed COM1 for the printer. Once I deleted the printer com1 became available and I was able to use both ports.... DUMB! You'd think I hadn't been doing computer stuff for 40 years!
Thanks to everyone for their thoughts, -john-
PostPosted: Thu Jan 31, 2013 4:42 pm
How do I install the EC software?
I'm want to up grade the BIOS but am told I must also upgrade the EC software and have no idea if it a Windows app or if it is something like the BIOS and must be install using a floppy. Any guidiance appreciated...
thanks, -john-
PostPosted: Fri Feb 08, 2013 2:39 pm
I did some bios updates on toughbooks some years ago, but since my last ultimate fail (I bricked a CF-M34 mk2 thanks to a bad version of the bios update), i didnt try again.
Anyhow, if my memory still works good, the EC update works the same way as the bios update.
What i did was this:
take a spare harddrive (the smaller the better, example 2 or 3 gigs)
format on another computer with MS-DOS 6.2 or so.
put both the EC update and BIOS update in 2 seperate directories (to make sure you do NOT mix them up)
insert harddrive in your CF-17
go to the directory of the EC-update, run the ec-update (its a .BAT or .COM .EXE file.....)
i think, after the update the CF-17 reboots.
then run the BIOS update.
Maybe some other members of this forum know more about this .
Update: I found this information that is the solution for your problem:
http://toughbook.wikispaces.com/message ... 4/32850336
of course you have to use the EC and BIOS update for your CF-17 and not for the CF-M34.
PostPosted: Fri Feb 08, 2013 3:04 pm
Thanks, so much, for taking the time to respond. Can you tell me what the 'EC' is? thanks,
thanks, -john-
