It is currently Mon Jan 21, 2019 8:25 am
 Post subject: Linux and CF-M34CGFZKM
PostPosted: Sun May 20, 2012 4:25 pm
First I added 256 ram for total of 512. It's all I had laying around.
I have tried:
Mint 8 via Panasonic CF-VRDRT3 usb MULTI PLAYER.--good one
DSL (dam small linux) I personally don't like it, others do. Very quick.
Ubuntu Light-----problem understanding wireless set-up.
Puppy Linux-----I'm not used to it.
And here I am back at my Ubuntu 10.10 Custom disk...(Pen Drive)
Ubuntu turned off (muted) the sound. Clicked it on and we're rolling.
FYI
Jeff...waiting on a hdd... :salute:
PostPosted: Sun May 20, 2012 8:08 pm
Sadlmkr wrote:
First I added 256 133 ram for total of 512.
I'm pretty sure the Mk7 /C / 1 MHz model uses DDR ram. I've built up several in the past, and the good thing about this model was a total 1.25 GB ram using the on-board 256 MB plus another 1 GB stick of DDR. Plenty to run XP.
I know 133 ram does not fit in a DDR slot, so maybe yours is "special"?
PostPosted: Sun May 20, 2012 8:13 pm
I could very well be mistaken...I looked at two sticks and probably got the numbers wrong. It was 256 something. I'll tell you the real number when I open it again. It was dark. :D
Whoaaa the sun came up again.
Changing the battery in my cell phone I remembered this:
PostPosted: Mon May 21, 2012 3:42 pm
You were correct Ken..256 PC 2100. I'll test 2700 512 in a bit....for total of 768...plenty for Linux.
J
