It is currently Sun Jun 24, 2018 12:44 am
 Post subject: Samsung Galaxy S7
PostPosted: Sat Jan 06, 2018 2:27 pm
I got a new to me phone. Galaxy S7 32gb
$125 because the back is cracked.
I ordered a good back and the adhesive. Also a funky suction cup clamp to assist in removal.
Figured while the back was off, I should change the battery.
Bought a new battery that the seller insisted was genuine. It's not. I am waiting for a response.
Anyway. I am looking at buying a set of earphones for it. Wired, not Bluetooth. In the ear canal type. Never had a set before. I want ones that have the 3 buttons so I can easily adjust volume.
I see some 3 button ones listed as Iphone compatible only.
Whats the difference? Why will they not work on Android phones?
Also checking out an app called Adhell. Any experience?
 Post subject: Re: Samsung Galaxy S7
PostPosted: Sun Jan 28, 2018 10:34 am
Bought a junker phone to learn the back removal.
Heat gun works but a hotplate would be better. Might get a cheap one. Im sure I can find uses for it.
