It is currently Tue Feb 25, 2020 5:50 pm
 Post subject: Antivirus
PostPosted: Sat Aug 02, 2014 7:26 am
Is there any antivirus programs that allow you to choose to IGNORE a "threat"? I used to be able to, but it seems they all are going to automatically erase my bleeping file..Or at best not allow me to run it....
Yes I know I have questionable files........
 Post subject: Re: Antivirus
PostPosted: Sat Aug 02, 2014 7:44 am
Bitdefender and Avast will let you with some hassle,they will quarantine the file but you can restore and put an exception in. Avast you can also rightclick and turn off for 10 min or more.
PostPosted: Sat Aug 02, 2014 10:43 am
All the ones I have had, have let me in the past to restore my hacking programs when needed. Need to go to your vault and restore from there. What antivirus are you using?
Alienware M11x R1
PostPosted: Mon Aug 11, 2014 9:22 pm
Avast will generally let you turn off various parts of the program for a specified period of time, from several minutes to indefinitely, depending on the feature you wish to disable.
PostPosted: Tue Aug 12, 2014 10:25 am
The best piece of kit I've used for stuff like this was a corporate version of McAfee
McAfee Enterprise v8.1
Not really good for home use
PostPosted: Tue Aug 12, 2014 4:25 pm
I am going to try Comodo free
