It is currently Mon Feb 18, 2019 1:14 am
 Post subject: recovery CD to USB stick
PostPosted: Fri Sep 29, 2017 10:19 am
Looks like I have a dead CD drive on a CF-30. Can the Panasonic recovery CD data be transferred to USB stick, for boot?
Thanks Again, Steve C
PostPosted: Fri Sep 29, 2017 12:42 pm
No one has made it work so far for any of the dvd based recovery disks.
It will boot and then stall. It it hardcoded to read from the optical drive.
I am sure some quick editing of some configuration file would cure it.
But I am a hardware guy and I lack the software skills
PostPosted: Fri Sep 29, 2017 12:44 pm
Maybe if someone would boot the standard windows recovery and then point it to the wim file from the dvd.
PostPosted: Fri Sep 29, 2017 2:53 pm
Send me a ISO that has been copied sector by sector from the CD, I think I know a way.
PostPosted: Fri Sep 29, 2017 7:47 pm
Do you have any other toughbooks with a dvd drive?
Alienware M11x R1
PostPosted: Mon Oct 02, 2017 9:13 am
Give me an address and I can mail the dvd to you.
PostPosted: Mon Oct 02, 2017 11:23 am
Thanks Shaun, I have the panasonic recovery CD. I though it would
be nice to have a USB recovery stick. No big deal, i will just put a good drive in it, temporarily.
Thanks to all for the response,
Steve Carlisle
PostPosted: Mon Oct 02, 2017 12:32 pm
I swapped a blu ray into the optical caddy for my CF31 and CF 52
PostPosted: Thu Oct 05, 2017 7:15 pm
Shaun, how'd ya do dat?
Steve
PostPosted: Fri Oct 06, 2017 5:08 pm
Pulled out the dead dvd from the plastic caddy. 4 screws.
I will find photos and post them.
