It is currently Sat Feb 16, 2019 10:12 pm
PostPosted: Sat Apr 16, 2016 9:00 pm
As the subject line reads will a backlit keyboard from a CF-29 work on a CF-30 computer??
Thanks..
PostPosted: Sat Apr 16, 2016 9:18 pm
Yes.
Also 31......ummm and 53.
52 GUN doesn't need it with red backlit LED. This is the Touchscreen version with CF-30 style LCD.
Regular 52............I don't know. Somebody?
PostPosted: Sun Apr 17, 2016 3:12 am
They work on MY CF52.
You need to add the wiring on a CF52 for it to light. Otherwise it fits and works as a non lighted keyboard.
PostPosted: Sun Apr 17, 2016 9:32 am
thanks guys
PostPosted: Sun Apr 17, 2016 9:33 am
thanks guys, anything special I need to know on doing the switch?
PostPosted: Sun Apr 17, 2016 10:27 am
The original keyboards are glued and or pinned on. They can be difficult to remove without damage.
https://www.youtube.com/watch?v=-Dl173wLr3E
