It is currently Wed Feb 20, 2019 6:06 am
 Post subject: widows 7 reload
PostPosted: Sat Feb 06, 2016 6:19 pm
I have a cf30
model cf-30ctsazbm
purchased a couple of years ago loaded with both xp and 7
i thought it would be a good idea as one of the programs i use for my business will not work on 7.
well over time i decided not to use that program making xp unimportant to me. plus the partition takes up 38 gigs on the hard drive, which would be nice to have use of.
also, touch screen is not working properly...when i touch the screen, the pointer moves all the way to the right side of the screen, allowing me to only scroll the page up and down.
Don't know how to fix this issue.
so, i was just thinking of reloading with windows 7(This will help with the partition issue and hopefully the touch screen issue), but i am a little worried about getting all the drivers loaded correctly.
so I was wondering if there is any one here that would be willing to talk me though it via phone if i have any questions or run into any problems.
Thanks, Kevin.
