It is currently Thu Jul 19, 2018 9:28 am
 Post subject: CF-30 upgrade to Win 10
PostPosted: Tue Dec 22, 2015 5:15 pm
I just successfully upgraded my CF-30 Mk2 from Win 8 to Win 10 (despite the Windows notification that it couldn't be done because the CPU was incompatible with the upgrade). Everything seems to work great, including the touchscreen. The one problem is that the internal SD card reader is not recognized anymore by the computer.
All the drivers are up to date and there are no exclamation points next to any entry in Device Manager, but I can't get the computer to read the SD card or to even acknowledge that it has been inserted (no audible sound or green light).
Is this because there is no Toughbook compatible SD card driver for Win 10? Has anyone else experienced this?
Thoughts and suggestions would be most appreciated.
